temperature and oil pressure gauge
Old 05-17-2006, 12:57 AM
Wicked illusions's Avatar
Default tempearature and oil pressure gauge Q's
just bought my 2001 SS SOM, 62500 mi, T-tops, M6, Tan/black interior,flowmaster, for 15500.00. I love the car. car is mostly stock and drives strong. I had some concerns about a few things. First my oil pressure gauge starts at 40 and when I step on the gas it moves to about 60. Is this normal? and my temperature gauge is at Half way sometimes a bit below half way. Should it be at a quarter? or is my reading ok? I just thought it might be running a little hotter than what it should be. Maybe its just me.....
Old 05-17-2006, 05:35 PM
04goatinmass's Avatar
sounds normal.i wouldnt worry about anything.you must have a 180degree therm.does it stay just below 210?if so then its a 180.as for the oil that sounds right .ls1 run hot
Old 05-17-2006, 10:21 PM
Tech Resident
ChocoTaco369's Avatar
a 2001 temp gauge doesn't work. it's only good for noting if the car is cold or overheating. otherwise it'll be a millimeter before 210 all the time.
Old 05-18-2006, 10:39 AM
Wolfmanjohn's Avatar
That's the correct range for the oil pressure, too. And, yes, as noted above, the temp gauge is pretty much a dummy.
