platinum spark plugs?
Old 05-28-2006, 09:01 PM
Yellowbrother's Avatar
Default spark plugs...yes i've search...keke
i see most recommend or is using ngk tr55...i'm assuming it's the gp platinum...has anyone used the double platinum???
http://www.ngk.com/results_app.asp?AAIA=1358546
Old 05-28-2006, 09:49 PM
taintedmeat's Avatar
I think most people are just using the V-Power plugs. I know I am
Old 05-28-2006, 09:55 PM
wat's the vpower made of???
Old 05-28-2006, 09:58 PM
Smile
Copper I believe http://www.ngk.com/more_info.asp?AAIA=1358546&pid=2411
Old 05-28-2006, 10:06 PM
any reason to use a copper spark plug instead of platinum??? my maxima came stock with ngk platinum...and those guys only use copper when they go n2o or force induction...
Old 05-28-2006, 10:13 PM
Because they're cheap, and you don't have to worry about the platinum disc burning off of the electrode. I would choose iridium over platinum, but I'm not spending 8 dollars per plug. I'm fine changing them once a year and sticking with copper V-Powers.
Old 05-28-2006, 10:24 PM
interesting...so for the most part it's just becuz of price???
Old 05-28-2006, 10:27 PM
In my case, hopefully someone else will reply with more info.
Old 05-29-2006, 12:04 AM
That's what she said...
TheBlurLS1's Avatar
Yes, the price is the main reason why people use the tr-55 v-powers. You could change them out 4 times for what a set of iridiums cost. You can buy a whole set for $16. I ordered some NGK tr-55 iridiums last night from Thunder, only because I was ordering some other stuff and wanted to try them out.
They are having an everything's 10% off sale.
thunderracing.com
Old 05-29-2006, 03:42 AM
Formy's Avatar
I went with the NGKs. Part number 3951. I just could not justify spending 8 bucks a pop on a part that I was eventually going to throw away. Gotta say the car is running quite smooth.
Old 05-29-2006, 05:54 AM
the ngk that came with my maxima and what i replace with are around 5 bux a pop...the ls1 is outta my car rite now with headers off and everything so i figure i'd change out the plug...but from what i've read alot of hybrids with ls1 have a big problem getting to the plugs in the back i'd figure i use the platinum so it'll last a lil longer and not have to get in there as much...
Old 05-29-2006, 11:28 AM
You have an ls1 in your Maxima? Pics?
Old 05-29-2006, 11:53 AM
haha...no...my maxima is my daily driver...keke...silly boi...too much work to convert fwd to rwd...i was just saying that the plat ngk for my maxima is about 5 dolla a pop...and with the difficulties that i've been reading on when the motor is in the car it's hard to get access to the rear spark plugs...i'm putting the ls1 into a z32...just got done with the mount...need to fab up the firewall and tranny tunnel...i'm changing whateva i can now while the motor is out...but if indeed it's that hard to change out the rear spark plugs i mite as well buy the plat and forget bout it for a while...
Old 05-29-2006, 12:01 PM
Sounds like it's gonna be a sweet car. A z32 Fairlady ls1
Old 05-29-2006, 12:04 PM
JDP
JDP's Avatar
i heard copper conducts better than platinum, correct me if im wrong
Old 05-29-2006, 12:11 PM
allngn_c5's Avatar
LS1 plugs aren't that bad. Its about 30 minutes a side. Should be one of the first things you do every season if you have a lot of money in your car. In March 07 or whenever Michigan says she can come out and play next spring I'll be filling her up with Amoco Ultimate, and dropping in some new NGK's. I run 1 # colder plugs to help protect against pre - detonation. So for 1 hour and $20 you can have a new running car every season. Wires probably every 3rd season unless I don't drive much. Those headers cook the hell otta my wires. JMO
Old 05-29-2006, 03:30 PM
Asmodeus's Avatar
I just put a set of Denso Iridiums in with my LT/Y-pipe install.
http://www.densoiridium.com/
Old 05-29-2006, 09:49 PM
i sure hope it is...now need to hunt down minor parts...
Old 06-07-2006, 08:51 AM
from a small research that i've done...it appears like of all the major conductor...only silver has better conduction property then copper..gold has less conduction property but is desireable becuz it is not prone to corrosion...and corrosion is the flaw of copper...i'm assuming y platinum cost more is due to this same property as gold that it's not prone to corrosion thus better conduction in the long run??? this is only my assumption based on what i've found so can anyone confirm this???
Old 06-07-2006, 09:07 AM
Mike02Z's Avatar
I took the denso iridium's out when I just changed mine. They looked Ok but the gap was like .070. I was not sure how long they were in there. Did the 02 Z come with the Denso's originally does anyone know? I think the 02 did come with iridiums originally. I went with the TR55's. I put 2500 miles a year on my car so these should last me a good 4 years and I couldn't justify the price difference in that after 4 years I'd change plugs no matter what kind I used.
