A/C on at idle kills car?
Old 05-30-2006, 08:34 PM
Valkyn's Avatar
Default A/C on at idle kills car?
Was very hot here today, and I was driving in pretty heavy traffic with alot of lights and such. Everytime I stopped, I had to turn my AC off or it would bog the car down to about 500 RPMs, some sometimes completely stall it.
It seemed to not be quite as bad if I put it on the AC setting that is furthest to the right, sometimes it would idle okay, others it would still pull the engine down.
Is this common with a cammed car? Or is my compressor going bad or something and putting too much load on the engine?
Old 05-30-2006, 09:53 PM
2002 SS #476's Avatar
It's probably the A/C compressor locking up, which can cause the engine to stall since the A/C belt runs of the crank.
Old 05-30-2006, 10:54 PM
1BADAIR's Avatar
if you have a cam the a/c idle and some other stuff need changed to get it to idle
Old 05-31-2006, 05:50 PM
WhiteRhino's Avatar
Like !badair said your ac idle on needs to be turned up do to the cam. Its pretty common with all cammed cars. I had my car tuned with the ac on as well, just so it would drive good with the ac on.
