Air control selector for heat and AC no longer workers after cam install
Last year I installed a cam and LS6 intake and removed the A.I.R. and EGR systems. I drove the car for a couple of months before storing it for the winter. During this time I didn't use the heat or AC, so I didn't notice any problem. However, when I took the car out of storage this year I noticed the air control selector didn't work. For instance, if I put the heat on the air will blow out of the lower vent and the defrost at the same time; no matter where I position the air control selecter (e.g., if I put the air selector on the dash vents the air still blows out of the lower vent and the defrost). I have no clue if this is related to the cam change, but I find it strange that the problem arose after the install. Does anyone have any suggestions for how I can fix this problem?
Thanks,
Jim
Thanks,
Jim
Do you know specifically where to look (e.g., in the back of the intake)? Last week I looked around for a disconnected vacuum line, but didn't find anything. However, I really didn't know where to look, so it wouldn't surprise me if I missed it.
Thanks,
Jim
Thanks,
Jim
Originally Posted by 2001NBMZ28
Yeah, look behind the intake.
A vacuum hose was disconnected from the back of the intake manifold.
When I installed the cam and intake I removed the A.I.R. system. The A.I.R. system pulled vacuum from the back of the intake. So when I installed the new intake I put a cap on both vacuum ports (for lack of a better word). I thought both went to the A.I.R system, but I was wrong. One went to the A.I.R. system and one went to the air control selector. I did not notice a problem during the install, because when I pulled the original intake I tucked the air control vacuum line up under the cowl to get it out of the way. During the install I forgot about it. So to solve the problem I search around for a disconnected vacuum line. When I found it I immediately realized what had happened. After 45 minutes of screwing around I was finally able to remove the cap from the back of the intake and connect the vacuum line, which solved the problem.
I guess I can't complain. This was my first cam install and that was the only problem/ stupid mistake I ran in to.
Jim
Jim
