how hard is it to install PHR??
Old 06-05-2006, 11:28 PM
TX_SS's Avatar
Default how hard is it to install PHR??
im getting a BMR ADJ PANHARD ROD... how hard is it to install? is it simple bolt-on?? any advice??
Old 06-06-2006, 12:11 AM
spy2520's Avatar
easy, only two bolts
Old 06-06-2006, 12:21 AM
9silverbird8's Avatar
installation is easy. 2 bolts as stated above. adjustment is the thing that was a PITA, at least for me.
Old 06-06-2006, 09:15 AM
TX_SS's Avatar
how do i properly adjust it??
Old 06-06-2006, 12:47 PM
2001NBMZ28's Avatar
Install is easy...comes with instructions, you can also view/download them from BMRs website. Measure the stock bar bolt holes center to center, then transfer that measurement to the new one to start - adjust from there if needed. Get a helper, you may need to push in on the tire/wheel to get the second bolt through if the rear moves.
