Steering boot leak
Steering boot leak
I did a search, but I only found power steering leak issues. Anyway, I noticed my left rubber steering boot has fluid around it. I know you undo the tie rod and slide the old boot off and put a new one on. Do you need to fill it with gear lube? The manual doesn't say to, but I'm assuming that is what is leaking. Also, how would you fill it? Thanks!
