Vibration/Clunk/WTF?
So when ever my car is under some torque (first and second gear under normal driving) It makes this clunking noise that kinda changes into a vibration with the rpms. It is coming from the around the trans/rear of the engine. I noticed that my shifter was vibrating alot and you could see it move with the clunking so I changed the trans mount. That didnt help, and I think by going to poly I just excentuated the problem. I bought a Torque arm bushing but I havent put it in yet, however, I am starting to think that wont fix it either. Yesterday I noticed I could really feel the noise comming from the tunnel/floorboard/firewall. Motor mounts? kinda confused with a problem that is kinda hard to describe. Let me know if anyone has any ideas.
First check everything. Look at the torque are bushing and see if that's gone to ****. If so replace it and see if that fixed the problem. If not then my guess is motor mounts. I just got done replacing my torque side motor mount with a energy suspension poly one. The install was a real PITA!
