Oil Change light
Oil Change light
I changed my oil two weeks ago. I used Mobil 1 5w-30.
Took 6qts even. The oil line on the dipstick is dead smack inthe middle of the operating range.
My oil pressure is fine. But here for the last few days everytime I start my car the "Oil Change" light comes on. And stays on until the car is warmed up. Even then it will come on every now and then. Then turn off if I give it a little gas.
What gives?
What gives?
Originally Posted by 2K2WS6TA
You can also turn the key to on (don't start the car) and floor the gas pedal 3 times, that shuts off the oil change light without resetting your trip odo (that is if you care about your trip mileage and don't want to loose it)
What rpm? If you say redline I know your fawking with me.
Originally Posted by Justin00SS
So I just rev it up?
Originally Posted by staringback05
6 qts? holy crap...u sure?
I put 6 in. Measured. Its in the middle of the XXXXXXX operating area. Its only been two weeks. Hasn't moved a bit.
Also this did reset the light.
