poping sound when turning and stoping
hey guy i just noticed a problem with my car that just started today.
it makes a poping sound when turning left and some times when i come to a stop it will pop right before the car compleatly stops.
it sounds like its coming from the drivers side.
any ideas????????????????
My car done the same thing, it's a 98 Z-28, so I took it in to the chevy dealer and found out that the drivers side upper control arm was bent and cracked. I could literally grab it and jerk it around while the car was on the ground. Might check the ball joints too, if one of them is bad then it would cause the front suspension to be loose and pop. Hope this helps
