i think my cars ruined please help :(
last night there was some pretty heavy rain but i only drove in it for about 20 min but there was alot of water on the road(no puddles just wet) anyways this morning i get in my car and it smeels horrible i come to find out the WHOLE DRIVERS SIDE under the mats is flooded....i dono WTF to do and if its even worth redoing or if i should junst ****** sell it and get a new one ive had everything possible go wrong on this damn car
Pull the carpet back and see if you can figure out where it's coming from, check around the firewall area and weatherstripping too - use a garden hose if necessary. If it smelled really bad doubt it happened overnight and just a 20 min drive, could be something that's been going on for a while.
welll every once in a while i get a little spot under the drivers side floor mat but this time it was the WHOLE drivers side and ALOT of water...and i dont wanna pull the carpet cause id have to pull out the seat and stuff any help greatly appreciated
If your carpet is soaked...
Pull it out. Period. It won't dry out inside the car. Yes, it's a pain in the ***. But it's what you MUST do to dry your carpet out.
My 98Z leaked at the rear hatch weatherstrip. A little bit of gooey gasket sealant held the weatherstrip in place, and applied judiciously, no more leaks. Yours sounds more severe. But if you want to save your carpet and padding material, pull it now (and stick your seats back in while it drys - yeah, ghetto looking, but hey, it's either that or reek of mold and mildew).
Who knows, you could have a missing drain plug in the floor pan or something. Won't know until you pull the carpet, and then test the car for leaks.
Come on Who....you absolutely have to pull that carpet out. Its an easy job to get it out....yes, a pain in the butt, but you are in for bigger problems down the road if you dont.
Pull your seats, the console, and the trim pieces holding the carpet around the doors. Take your time and you will be fine.....and its a whole lot cheaper than buying a new car.
R/
Frat
R/
Frat
ok pulled out the carpet just cut out the whole drivers side ITS RUINED!! but now it seems like the leak is coming from up in the firwall sumwhere that i cant get to i think ima just take it sumwhere and tell them to fix it....
pull your cowl panel between the windshield and the hood. The black plastic piece see if there is anything blocking the drain holes under there first. Just test it with a water hose have someone set in the car with a light and try to pin point it..
OWN3D BY MY PROF!
If your car is loosing water from the cooling system it might be the heater core. That happened in my 95 eclipse GST. Water all over the passenger side that I couldn't tell where it was coming from and a weird smell. I tried to pull the whole unit out, but couldn't get the dash out after 14 hours of working on it, so I just bypassed it. I split the input and output to the core and then used a double male pipe connector to connect them, that only took ten minutes.
Check the grommet for the hood release cable where it goes thru the firewall. That was where mine was leaking. The grommet was popped out of the firewall and I just popped it back in to fix the leak.
