I need f@ckin help bad, ~~~~~~~~~~~~~~~~~~
Old 07-07-2006, 09:03 PM
mxmarc219's Avatar
Default I need f@ckin help bad, ~~~~~~~~~~~~~~~~~~
I ran out of gas 3 weeks ago in my 1998 trans am, n I have replaced the fuel pump and it still is not starting, and is only getting 12 psi of fuel?????what the ****>>>>>>>>>has anyone had any trouble with the fuel systems, and can someone take me thru step by step procedure of replacing the fuel pump???? And I have already replaced the fuel filter and that was not the trouble still no go, I unhooked the battery as well when I did the job!!!!! can anything in the pump be faulty or is it some sort of electrical connection I should be looking at!!!!! what would make the a brand new pump only disburse 12 psi???????PLEASE HELP THANKS IN ADVANCE......
Old 07-07-2006, 09:28 PM
Farmer2's Avatar
Did you get a good seal when you installed it inside the tank?
Might be leaking past back into the tank.
Old 07-08-2006, 10:57 AM
coolformula's Avatar
Fuel Filter could be clogged too sucking in all the crap when you ran it out of gas.
Old 07-08-2006, 08:11 PM
YouCantCmyZ28's Avatar
make sure you get the GM pump. have heard bad stories on cheap aftermarket pumps taken a s%@t on people
