Window Motor
Window Motor
Hopefully this is the right forum but anyways...Just got done installing a new window motor driver side. After looking at this website http://shbox.com/page/windowmotor.html , I found it very easy to do once I got to see how everything worked. I pulled off the door panel and saw that everything was worked on before by an amateur that just tore the panel all up with rivets and such. To make a long story short, I got the motor from Autozone 54.99 and some bolts came with it and it installed perfectly. I removed the motor in the up position and for the holes to line up on the new motor with old bracket, the window needs to be down. If anyone needs some advice, PM me or check out the link below. All the tools I used were 2 screwdrivers to remove panel, switches, screws- Leatherman tool- drill and some bits. Hope this helps
