Driver side window won't go down... not motor
Old 07-14-2006, 08:56 AM
horist's Avatar
Default Driver side window won't go down... not motor
Hey guys... I haven't torn the door apart yet, but before I do this weekend just looking to see if anyone has any suggestions on what may be busted
If I hit the window switch to lower the window... the window will drop a TINY bit, then all you hear is the window motor going at it... but the window doesn't move
If i push it back up then it moves up (the movement is maybe 1mm ... barely anything, prolly just some safety latch locking in/out) a little, but again, window motor will just keep running
Any suggestions on what it could be? Also anyone have pics of what the inside of the door looks like?
Old 07-14-2006, 11:11 AM
Charging TA's Avatar
Maybe the motor is not tight and has slipped out of place (if the fiberglass has worn from stress?)
Old 07-14-2006, 12:23 PM
ZROCWS6's Avatar
To me it sounds like the window regulator cables have come out of place and allowing the motor to just spin and not do anything
