Who would be best to replace my windshield?
The windshield on my 02 TA took its 2nd rock hit this past weekend.
The 1st hit from last year wasnt really a problem, but the 2nd one cracked it on the pass side, and im sure it'll split sooner or later.
I'm very nervious about having the window replaced!
Is this something I should have the dealer work on, or are they no better that a creditable body/glass shop?
Also, I want the replacement glass to be as factory orginal as possbile.
any advice?
any advice?
http://www.safelite.com/
Just did an online quote for a windshield replacement:
Safelite Regular Price: $416.35
Sizzling Summer Savings: 47% Off
Your Price: $219.26 (+tax)
I work in the windshield glass industry. In order to get the 'original' type windshield you need to look at the small logo printed on your windshield. It should have a logo that says "LOF" printed on it. That stands for Libby-Owens-Ford; that company was purchsed several years ago by a company named Pilkington. They still use the 'LOF' trademark though. Since the F body cars were assembled in Canada I can tell you that our windshields were most likely produced at a Pilkington glass plant north of Toronto.
So.....to get the same 'LOF' trademark on the windshield you will most likely have to go to a dealer (which will cost more) or call around to independent windshield places and ask them which glass manufacturer they use for your car.
Here is why......there is a difference between 'replacement glass' and 'aftermarket glass'. Safelite produces aftermarket glass. They buy an OEM windshield and they reverse engineer it and place their 'Safelite' logo on it. Safelite produces a quality product but you will not have the 'original' stamped windshield.
When an OEM windshield manufacturer is producing a run of OEM windshields they will produce an amount at the end of their run to be sold as 'replacement' glass. Exactly the same as the OEM glass. Some go to the assembly plant and the rest go to distributors for resale.
Hope this helps explain how to get the 'original' stamped windshield. In my opinion, unless you are planning on keeping the car in a vacuum with little or no miles on it and pulling it out in 20 years as a collectors car.......I would go with Safelite. Great product and great price. You wont notice a difference at all.
You will be amazed at how fast they can R&R your windshield. Sometimes 10-15 minutes. I wouldnt worry about that either.
LS1Tech Administrator
Received 1,467 Likes
The glass is only part of the worry.
Another concern is the molding they use. I've seen the work done by some local glass retailers, the ones that come out to you at work or home and replace the glass in your driveway. Some of them replace the molding with something quite different than stock, and it tends to not seal as well.
If they replace your molding, be sure that they use OEM molding. If not, I'd get some from the dealer and supply it to them.
1-800-800-ASAP. They did my Camaro for 197.00 in my garage. NO LEAKS. Found a tiny TINY star on the inside about 2 months later, they came out and fixed (replaced) it for FREE. The first time they use their Safelite company glass. If it has a defect, they will replace it for free with FACTORY GM Glass. Good people. Lined up T Tops perfect both times. Good Luck
I had a private replacement company come out to the house and I paid for the "replacement glass." Took about an hour. Got a Pilkington Windshield. They used a GM gasket. I was told not to drive the car for 24 hours as the silicone sets up. Doesn't leak. Works great.
There is some great info in this thread.
Tech Resident
yea my mom got hit by a stone from a big tractor trailor and it cracked her windshield. it was a small dot, but after 2 months spidered into a big crack. a company came out and installed the glass in 15 minutes for under $200. they basically told her you could just get a plate number from any big truck and submit it you insurance and they'd cover it...though i can't guarantee that...point is, it's 6 months later and it's just as good as stock.
I have been intalling windshields for 15 years dont go to the dealership go to a certified shop. Your car should never have to set for 24 hours that is just crazy that means they are just using cheap *** glue.. Where are you located I am with the 4th largest autoglass company maybe I can help you out...
I am with auto glass center.. We dont have anything up there sorry amn I could have hooked u up.. And he did not use a black silicone to put your windshield in it was urathane. The urathanes out today ofcourse there are several brans a several diffferent cure times. The glue we use cures in 30 minutes it is expensive to buy but well worth the money. And make sure you know what brand of glass they will be putting in and ask if there techs are certified as well.
As it turns out, safelite hasnt bothered to return my 2 calls to thier shop - so I wont be using them.
Instead, I took the advice from above, and found a glass shop that specializes in OEM glass, and yes, they use Pilkington! I'll call thier shop next week.
