power stearing fluid/leak ??
Old 07-17-2006, 11:55 AM
DZBIRD's Avatar
Default power stearing fluid/leak ??
has anyone had problems with the power steering fluid running low.........or any tips where to look for leaks
Old 07-18-2006, 12:18 PM
DZBIRD's Avatar
anyone ??????
Old 08-31-2006, 04:44 PM
SuperCuban's Avatar
Ya i went to get my tires changed out and the guy noted i was leakin from the rack and pinion and that part needed to be replaced. IDK if he was just bullshiting me or what but ya my power steering leaks too
Old 08-31-2006, 05:33 PM
BitViper's Avatar
I think allot of our cars leak from the reservoir.. mie is always "weeping"
Old 09-03-2006, 05:08 PM
Restricted User
fenix99's Avatar
mine just started leaking out of the rack n pinion....86,000 miles who needs power steering when all i like to do is go fast in a straight line lol
Old 09-03-2006, 07:05 PM
HeapaShifter's Avatar
Check the seals on the PS pump.
Check the ends of the steering rack.
Check the two lines that connect the pump & rack and check where the lines connect.
Also the power steering cooler if you have one. Most don't.
That's all that can leak power steering fluid.
Old 09-05-2006, 03:13 PM
CaliboyTA's Avatar
my power steering was leaking for quite a while. I really couldn't pinpoint where was the leak coming from cuz there so much power steering fluid all over the undercarriage of the car. I ended up getting the engine/undercarriage steamcleaned. after that I could definatly find where the leak was located.
Old 09-07-2006, 06:30 AM
pjb
pjb's Avatar
mine leaked PS fluid in to the cooling system. do a search on PS cooler to get details.
Old 09-07-2006, 11:48 AM
LS69TA's Avatar
Mine was low the last time I checked. I didn't see any leaks, so I may check the cooling system, I didn't think about the PS cooler leaking internally.
Old 10-06-2006, 06:10 PM
rebel's Avatar
mine is "weeping as stated. need to look into that
