front studs
Old 07-17-2006, 12:55 PM
rbobryk20's Avatar
Default front studs
I need to replace all 5 of the studs that hold the front right tire to the car. Car has brakes/studs/spindles off of a 98+ camaro/TA figured id include that don't know if it makes a difference. Is looks like u can bang out the old studs and replace them but i just wanted to ask someone before starting this ordeal. any tips for doing this process would be greatly appreciated.
Old 07-18-2006, 08:43 AM
jkichline's Avatar
I haven't done this on a car but on a trailer that I did, I pressed them out with a big C-Clamp and pressed them back in with a C-clamp. You can use a big socket or something to fit around the stud to get it out and back in. Wasn't too tough. Just use care when you put the new ones in that you don't damage the threads.
