white smoke at startup???
Old 07-22-2006, 12:56 AM
86MonteSS's Avatar
Default white smoke at startup???
ah!!! what is this!! its scaring the crap out of me! it doesn't smoke at all when its going, just when i start it (warm engine). what could be the cause?
Old 07-22-2006, 02:09 AM
staringback05's Avatar
how many miles? and what are the specs on your car?....and if you cut it off and then turned it back on does it do it? or does it have to sit for a bit and become cool again?
Old 07-22-2006, 02:11 AM
gun4hire's Avatar
what color is the smoke? If its black, you may have leaky valve seals which let a little oil drip down the valves into the cylinder while the car sits.
Old 07-22-2006, 03:26 PM
86MonteSS's Avatar
its white smoke. it happens a lot at gas stations and stuff, so it doesn't have a LOT of time to cool off.
Old 07-22-2006, 04:02 PM
santino04's Avatar
Get your sniffer down there and smell it...Does it smell sweet like antifreeze, that would be very very bad if it did!! Coolant leaking into cylinders!!!.... Possibly condensation may be coz, but it sounds like ur warmed up. Other wise u may be burning oil which more bluish if oil, or black rich fuel mixture....Good Luck
Old 07-22-2006, 05:35 PM
86MonteSS's Avatar
its probably oil. i have a leaking rear main seal (and a massive cam) so i have to fill it up every once in a while and i think i put too much in last time.
Old 07-22-2006, 08:34 PM
yea sounds like oil....what head work do you have done?
Old 07-22-2006, 11:04 PM
gun4hire's Avatar
if you've got a seal leak and put too much in, then just check your oil level. If its at the full mark or lower, then there isn't any way it should be being burned off like that.
Hopefully, its not a blown head gasket.
Old 07-23-2006, 12:33 AM
86MonteSS's Avatar
the blown head gasket would put out smoke all the time, wouldn't it?
ported and polished stock heads. TR224 cam (.590 lift)
Old 07-23-2006, 01:37 AM
are you talking about a blown head gasket? or the rear main seal?...the head gasket, your car would over heat like a mother....the rear would leak the oil....what kinda of springs and valves do you have? valves can not seat right sometimes after head work and theyll leak into the piston
Old 07-23-2006, 04:31 PM
00'WS6Rocket's Avatar
May indicate damaged valve seals. The smoke, which in most cases disappears after a few seconds, comes from motor oil that has seeped past the valve seals and into the combustion chamber when the engine is turned off.
Old 07-23-2006, 10:40 PM
86MonteSS's Avatar
ok, i've got it showing up in another spot now too. if i'm at a slow roll and i nail it in first gear, it smokes like crazy (i'm pretty sure it isn't tire smoke, but i could be wrong)
Old 07-24-2006, 09:13 PM
86MonteSS's Avatar
*bump*
Old 07-24-2006, 11:22 PM
z28_n_tx's Avatar
im having a similar prob...it seems to be white smoke on mine. checked the oil everything is normal (except for the normal small comsuption due to piston slap). Does seem like the coolant is getting in the oil. Car doesnt overheat either. i just got my LT's and ORY put on about a month and 1/2, didnt get mine tuned. But i dont think this is my prob. otherwise i would have black smoke right??? It does smell like gas and i get the burning sensation in my eyes if i stand too close. and l ike you , it doesnt due all the time, i just notice it yesterday, didnt do it this morning, but did do it again tonight. but i seems to disappear before it even makes it to the spoiler area.....condensation???
bump for us
z28_n_tx's Avatar
Old 07-26-2006, 08:39 PM
86MonteSS's Avatar
i figured out that its my valve guide seals. my air filter is nasty....
