time to change plugs?
Old 08-11-2006, 02:00 PM
knight rider WS6's Avatar
Default time to change plugs?
my ws6 is 5 years old, but only has 25,000 miles on it. Should I do plugs and wires? Would it perk it up more? I would be going with delco.
Old 08-11-2006, 02:10 PM
jmm98LS1's Avatar
Wires are probably ok, but you should probably change the plugs. The little platinum discs on the factory plugs are probably gone by now (mine were at 40k miles), leaving your spark plug gaps pretty wide.
Old 08-11-2006, 02:32 PM
I've heard you gotta do wires same time as plugs.
Old 08-11-2006, 03:23 PM
jmm98LS1's Avatar
Nah, as long as none are damaged the stockers are fine unless you really feel like changing them. I would have left my stockers on but I ripped one removing it.....have msd's now and they work great!
Old 08-11-2006, 05:05 PM
staringback05's Avatar
go away and do them all, the delco iridiums are pretty good i run them in my car
Old 08-13-2006, 08:26 PM
sssmokin99's Avatar
I also used the AC Iridiums and Magnecor wires. I only changed the plugs because I didn't want them getting stuck- the car is low mileage and a '99. I used alot of anti seize, and they went in easy. It is a nasty job to get to the passenger side though!
