cracked friggin block
Old 08-12-2006, 11:20 PM
spy2520's Avatar
Default cracked friggin block
not the best pics...
still dont know why it happened, almost finished a trans install...
Old 08-13-2006, 03:35 PM
RiceKilla's Avatar
Mine has a crack in the same spot but it was bought like that and didn't see it til I started the engine and saw oil leaking out.
Got the crack tig welded, and just plugging up the pin sized holes with jb weld.
Old 08-13-2006, 07:24 PM
spy2520's Avatar
any idea what caused it?
Old 08-13-2006, 10:07 PM
RiceKilla's Avatar
I am guessing maybe a rearend accident pushing the bellhousing. I bought it from a salvage yard, checked the VIN, CARFAX said the car was
wrecked/totaled.
It cracked the wing of aluminum behind the oil galley plug and the crack went down all the way to where the oil pan meets. Only thing I could do was slow down the oil leak so far. I am building up another block instead.
Old 08-13-2006, 10:09 PM
RiceKilla's Avatar
Here's mine. Goes up the oil galley. It even penetrated to the opposite side right next to the rear cover.
Old 08-14-2006, 12:21 AM
spy2520's Avatar
i am thinking the stress of the transmission pulling on the motor during installation cracked mine because it didnt start leaking until the transmission was just about all the way on the motor...
Old 08-14-2006, 04:02 AM
WILWAXU's Avatar
Yuck...
Seen that on the starter pad.. but not on that side.
Old 08-14-2006, 08:32 PM
spy2520's Avatar
i just went from a busted trans, to a beastly rock-on/fuddle combo and a cracked motor, what a trade that was, i think i liked my screwed trans better than this...
Old 08-14-2006, 09:11 PM
waterbug1999's Avatar
You running stock motor/trans mounts?
Old 08-14-2006, 09:14 PM
tsench's Avatar
thats y i ran with iron block
Old 08-14-2006, 11:54 PM
spy2520's Avatar
i am thinking about an iron shortblock, sure sounds nice right about now. i am running stock motor mounts, i have a poly trans mount i ran for about a week before i pulled the whole trans out...
Old 08-14-2006, 11:59 PM
Just asking because I have heard that its possible with a stock motor mount and a poly trans mount to crack either or (block/bell housing). Motor is "tweaking" and what not why the trans is not due to the poly trans mount. Just what I heard...
Old 08-19-2006, 07:04 PM
spy2520's Avatar
could be...i did think that might have caused it...
Old 08-21-2006, 12:53 PM
spy2520's Avatar
i figured out. block is fucked though...
Old 08-21-2006, 01:36 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
I am running stock motor mounts and a poly mount on my trans, t-56 though ( M6 ) in a very low power application, do you guys think that I will have a problem with this set up?
Old 08-21-2006, 04:21 PM
spy2520's Avatar
turns out my mounts had nothing to do with it...
Old 08-22-2006, 12:42 AM
quiksilver9531's Avatar
So what happened?
Old 08-22-2006, 01:15 PM
spy2520's Avatar
Originally Posted by spy2520
i fgured it out, you guys ever seen that little spacer/bushing that comes with a TCI flexplate?.................yeah well that **** aint supposed to go on there, the block is cracked from the bellhousing bolt close to the dowel on the passenger side all the way down to the oil galley plug above the oil filter. on top of that....pump is also broke on the trans...
turns out if i would have left that spacer out everything would have been fine, i tested it 100 times on the converter and on the crank to make sure they fit together, but never took into consideration the converter just might fit on the crank without it, what a major **** up that was...
pretty much sucks, f-body central says less than $3k and only a couple of days and i should be back on the road...
