pcv valve
It's on the passenger side of the intake manifold. Follow the rubber hose hooked to the pass. side of the throttle body. It's about 1/2 way between the front and rear of the intake by the valve cover. It's hard to believe the dealer wants a $150 for a $2 part and 5 minute job.
*edit* You have v6 in your name, if you do have a v6 I'm not sure if it's in the same place. I imagine it would be though. Just follow the rubber lines off your throttle body.
