poly trans mount installed now a vibration?
Old 08-22-2006, 11:59 PM
Restricted User
Chitown Racing's Avatar
Default poly trans mount installed now a vibration?
Had a bad trans mount installed a poly one. now the car vibrates like nobodys business. any ideas?
Old 08-23-2006, 12:44 AM
spy2520's Avatar
i did mine and it didnt vibrate at all, make sure you torqued everything, or if you didnt install it, make sure whoever did torqued everything, i truly believe if installed right there shouldnt be much vibration if any.
Old 08-23-2006, 01:26 AM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Give them a few days and miles to break in.. They sometimes are a rough ride at first.
Old 08-23-2006, 09:39 AM
A-Dub's Avatar
I haven't installed one on this car yet, but on the previous car I ground down the two preload bumps and then installed it. No vibrations
Old 08-23-2006, 01:50 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Leave the preload bumps.. I have a energy suspension peice, and it works great.
Old 08-23-2006, 02:47 PM
iamsickofitall's Avatar
my energy suspension mount added a tiny vibration for the first couple days and then it went 90% back to normal
Old 09-03-2006, 05:17 PM
Restricted User
fenix99's Avatar
my poly trans. mount shakes the **** outta my console and car...be4 it didnt do that =/
Old 09-04-2006, 04:53 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Aftermarket poly mounts will make it vibrate, especially if your tires have low tire pressure.
Some folks will run the 1LE GM trans mount, does not vibrate as bad.
