Grinding noise when shifting
I've noticed lately that in my automatic Trans Am, when I shift into reverse or drive, the car hesitates for a moment then does a bit of a lurch accompanied by a grinding noise. The noise sounds like its coming from the rear and the best way I can describe it is like rubbing two pieces of metal together with sand in between them - if that makes sense.
What could this be?
What could this be?
it's never going to be perfectly smooth when you put it in drive or reverse. It is going to lurch a bit.
Only thing in the rear is the differential right?
I don't think a torque converter would grind, but that's not in the back.
