Front hub rattling on small bumps
Old 08-28-2006, 12:48 PM
ActionJack's Avatar
Default Front hub rattling on small bumps
Anyone else have their hub start to feel loose and make noise over bumps?
I just had new schocks installed and right after the front right is making a rattle and the wheel has a wiggle.
If you have had this problem what part did you replace it with?
Old 08-28-2006, 08:07 PM
HeapaShifter's Avatar
Make sure your tie rods and ball joints have all been tightened.
Another thing: On the front shock; sometimes the nut on top of the spring perch doesn't get tightened down enough and it causes a noise.
Old 08-28-2006, 08:46 PM
ActionJack's Avatar
Thanks for the tips because my driver side had a noise on turns now and I think it is coming from around the tie rod.
