Chirp noise over bumps
Old 08-29-2006, 11:48 AM
maybe2fast's Avatar
Default Chirp noise over bumps
sounds like it is from the rear hatch area but can't find it because I have to be driving over bumps. has anyone experienced these chirps? thankz guys for any help
Old 08-29-2006, 12:27 PM
Tech Resident
ChocoTaco369's Avatar
i do. drives me NUTS! i'd LOVE to fix it!
Old 08-29-2006, 12:49 PM
Revelation Z28's Avatar
i think you have to do the !Bird mod
i have the noise in the front. its the suspension or something.
Old 08-29-2006, 01:46 PM
2KThunder's Avatar
I have the exact same noise I just atributed it to the 19 inch wheels rubbing, or something because I ahve lots of signs of rubbing in the wells
Old 08-29-2006, 02:43 PM
SS#2906's Avatar
I think most f-bodies have these squeaks and chirps. Both my 01' SS and 94' Z-28 have the same issue.
If you ever find the solution to this, let me know.
Old 08-29-2006, 02:53 PM
slowscott's Avatar
Soak all your bushings in white lithium grease. If you open your door and push down on the door sill and rock the car does it make the noise? Mine made a noise like a bird. Turned out to be the lca bushing...
Old 08-29-2006, 03:30 PM
Tech Resident
interesting. i'll have to try that sometime. looks like i may be breaking out the WD-40.
Old 08-29-2006, 08:34 PM
adamsmaross's Avatar
hey i had the same prob...my bro has a LT1 TA and i got a camaro ss. we both cranked down our spare tires and the noise went away....give it a try see if it works for you..
Old 08-30-2006, 12:29 PM
maybe2fast's Avatar
that is exactly where it sounds like its from! I will post any findings.
Old 08-30-2006, 07:21 PM
Pewterpower's Avatar
Sometimes the lug socket that is inside the handle (that folds into itself) will vibrate and squeak.
Old 08-30-2006, 10:20 PM
1999Z28's Avatar
spray the sway bar bushings with silicone spray
Old 08-31-2006, 07:18 AM
Tech Resident
you know what...
i always had this noise horrendously when i went over bumpy roads. however, last thursday i went to the track, so i took out my spare tire and jack. i reinstalled it when i got home. i haven't heard a rattle since. i think i may have accidently solved the creaking and chirping issue! lol you're the man.
i haven't noticed a single bump. i'll keep my ears out.
Old 08-31-2006, 10:42 PM
BigE's Avatar
Friend of mine on this forum had the same problem. It was a simple click or chirp when traversing uneven pavement. It turned out to be the rear sway bar bushing.
Old 05-05-2007, 11:08 AM
2002ws-6's Avatar
as mentioned above lube the sway bar bushings. I tried silicone spray and it helped but the sound only went away after removing the bushings and lubing them up right.
Old 05-05-2007, 11:33 AM
kaos_'s Avatar
not only the bushings, but you may have cracked bump stops if your car is lowered. i just found out mine were pretty bad. in which case it chirps like all hell! ahhh!
Old 05-06-2007, 10:14 PM
Silver UltraZ's Avatar
Yeah I did the same thing, I had the same chirp noise, Take yopu spare tire out and cover it with a tshit.. Garenteed solved
Old 05-06-2007, 10:20 PM
RealLiveMD's Avatar
Lived with it for 2 years, then found out it was the spare tire not fastened tightly.
Old 05-07-2007, 12:36 AM
clean99's Avatar
IM spraying everything with lithium grease tom morning.......this chirping noise is driving me nuts, i think its the lca bushings.
Old 05-07-2007, 01:44 AM
windows do it for me. when they are down 1/4-3/4 the way they chirp over bumps.
Quick Reply: Chirp noise over bumps
