Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
- Camaro General Information and Recommended Maintenance Schedule<br>Important information to help you understand your Camaro.
T-top maintenance?
T-top maintenance?
Whats the best maintenance for T-tops to prevent against leaks and such? I heard a friend say once to lubricate them a few times a year? Anyone have experience with this? What kind of lubrication do you use? Thanks.
get a couple packs of di-electric grease from napa or vatozone and have at the weather stripping.
i do it to my doors and hatch once a month. heat will rott them out when dry for too long.
had a 2002 Trans Am WS6. The first rain I was in, the T-Top leaked at eash rear ourside corner or at least thats where the water started dripping. Leaking T-Top are to be expected. I read in my manual to not use car washs because the pressure can deform the seals and cause leaks.
I doubt there is one out there that does not leak. If you do manage to stop if from leaking, it will have a leak again the next time you remove the top.
Something you have to live with T-Top. One thing to try is, silicon spray on the rubber. You should do that often to keep them soft. Look in the owners manual for the recommend lubricant.
Treat your roof as you would the rest of your car and it should last you a lifetime!
Windex or other standard ammonia based glass cleaners and a soft cloth work fine for normal cleaning. We do not recommend paper towels. For protection you may apply standard paste/liquid car wax. Avoid cleaner wax since it will most likely contain abrasives that may damage the hard coating of the lens.
The lens on your new roof is made from SAR (Super Abrasion Resistant) hard coated acrylic. Which, in other words, is plastic. Since plastics can be affected by heat we ask you try and keep your roof as cool as possible to maximize it’s life expectancy. On hot sunny days try to park under shade and keep your windows slightly opened to allow hot air to ventilate from the interior.
I have been using a old toothbrush and puting some black magic on the rubber. Been doing this for the past years and my top does not leak.
And mothers back to black works great to take off the water spots on the black t-bar.
Not to get off topic here but has anyone done anything to get them to stop rattling? My driver's side T-top is driving me crazy. I haven't tried anything yet so just wondering if there is something that can be put on them for this or a tightening up/adjustment that can be made? Oh yeah, sub frame connectors helped some but not much. Thanks for any experience on this. Nate
theres a way you can adjust the locking thing. jsut not sure how to do it
Originally Posted by Tainted
its a gm lubricant. its die-electric grease, it moisturizes the weather stripping and helps it seal better.
That number is straight from the owner's manual. I just picked up a tube at the dealer the other day. $8 or so. It's the same grease you use in your spark plug boots.
