GM Fluid Recomendations. W/ Part #'s.
GM Fluid Recommendations..98-02 F-Body
The following Specifications are out of my 2000 Z28's Owner's manual.
5.7L 346CID LS1 V8-........Owner's manual denotes SAE 5w30 is best. You can use SAE 10w30 if the temp is going to be above 0*F
Engine Coolant-...............Mix 50/50 w/ drinkable water. Use GM Goodwrench DEX-COOL or Havoline DEX-COOL
Hydraulic Brake Fluid.........Delco Supreme 11 (P/N. 12377967 or equivalent DOT 3 Brake Fluid)
Windshield Washer Fluid-...GM OptiKleen (GM P/N 1051515) .. or Equivalent
Hydraulic Clutch System-...Hydraulic Clutch Fluid (GM P/N 12345347, or Equivalent DOT 3 Brake Fluid)
Power Steering Fluid-........GM Power Steering Fluid (GM P/N 1052884 - 1 Pint 1050017 - 1 Quart, Or equivalent)
T56 6 speed Manual-........ Dextron III Automatic Transmission Fluid
4L60E 4 Speed Automatic-..Dextron III Automatic Transmission Fluid
Key Lock Clynders-............Multi-Purpose Lubricant, Superlube (GM P/N 12346241 or Equivalent)
Clutch Linkage Pivot Points-Engine Oil
Floor Shift Linkage-...........Lubriplate, Lubricant Aerosol (GM P/N 12346293 or Equivalent)
Limited Slip Rear End-........SAE 75w-90 Synthetic Axle Lubricant (GM P/N 12378261) or Equivalent. W/ a complete drain and refill, add 4oz (118ml) of Limited Slip Axle Lubricant Additive (GM P/N 1052358 or Equivalent)
Refrigerant Oil-.................PAG oil (Polyalkylene glycol)....16fl oz bottle of GM Delco "Refrigerant Oil R134a Systems" (other numbers on bottle: 1#12356151 Gr. 8.8 1#15-118) ONLY FOR R-134A SYSTEMS ... Ester oil should NOT be used in 134A System
There's more here, but I REALLY don't feel like posting them ALL.... Hood pivot points, latch grease... ... Just use some WD40...
Working on Fluid Capacities...
LS1 Engine- 5.5 Qts
3.8L V6- ..........
Power Steering Resvoir-
Coolant Overflow Resevoir-
Collant system (incl engine and rad)- should be 12 Qts
Brake Fluid Reservor-
Clutch Fluid Reservor-
Windshield Washer Reservor-
T56 56speed Manual transmission -4 Qts
4L60E 4 Speed Automatic Transmission - Tranny and Converter [Empty] Holds 11 quarts. Pan itself holds 5qts [service, filter and just drop pan]
Rear Axle-
Also Engine oil Analysis
Some interesting material in here!
http://web.camaross.com/forums/showthread.php?t=468712
LS1 Engine- 5.5 Qts
3.8L V6- ..........
Rear Axle-
Originally Posted by GhostZ28
I'm not sure if there are many people who haven't seen this, but it will definitely be a help to those who think changing your oil every 3k miles is a GOOD thing. A guy in the general tech section was convinced he was doing his engine a favor by changing the oil every 2,500-3,000 miles. I think this has come up on the LSx tech before but there seems to be a lot of new members posting here and those who haven't seen this will be just as surprised as I was.
All tests have been done on a stock 2002 LS1 powered Camaro Z28
Mobil 1 study: http://neptune.spacebears.com/cars/s.../oil-life.html
Amsoil study: http://neptune.spacebears.com/cars/stories/amsoil.html
Honepage: http://neptune.spacebears.com/index.html
This oil analysis study of major synthetic oil brands shows conclusively that it is better for an engine to leave synthetic oils (at least Mobil 1 and Amsoil) in the engine for at least 6-9k miles while periodically topping-off the oil and changing the filter around 4-5k miles.
