ever fill up and have gas squirt out?
Old 11-18-2006, 07:38 PM
DriveATransAm's Avatar
Default ever fill up and have gas squirt out?
drove to the station today, left the car running cause the engine was cold and i wanted to warm it up. sometimes the pumps work, sometimes they dont when i leave it running.
well, today it didnt work, so i shut the car off and it still didnt work. next thing i know i have gas pouring down the side of my car .
gas attendant was telling me my tank was full, even though i have 200 miles on on the tank and the gauge said E. there was gas above the little flapper so there was def. something wrong.
drove around for 10 mins, came home, and the gas above the flapper was gone. could it have created such a large air bubble that the gas wouldnt go down? the attendant was telling me that the pumps are designed for that.
ive never had this happen before. if someone stuck something in my tank i would think that it would push its way down inside of the tank and clog my pump before it would get stuck in the filler and prevent gas from going in.
and ideas?
Old 11-18-2006, 10:03 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,486 Likes on 1,069 Posts
Roy were you trying to put 87 octane in the tank? If so, the car was probably trying to give you the following message.....
LOL. J/K!
Old 11-19-2006, 07:55 AM
maybe
Old 11-25-2006, 02:51 PM
ok. so ive tried filling it up two times this week and only got a half gallon in each time. so i figured it must be full, and the gauge was broken.
after hte last fillup i reset the trip so i knew how far to drive. so im driving around, put 40 miles on with the needle way past E. im thinking, alright, 40 miles on E and i would have been empty by now if it really had no gas.
so i take it to work this morning to "empty" some of the gas for winter. well i get like 2 miles from my house and i run out of gas. as luck would have it i was passing a gas station just as my car started sputtering. i rolled into it and it died just as i came to a stop at the pump.
i wait around for 10 mins till they opened up. and what do you know, 16.5 freakin gallons go in. wtf.
now yesterday i stuck a coat hanger in the filler to see if i could measure how much gas was in it...but i could only get the hanger in like 8 inches.
so im totally confused now. if something were stuck in the filler tube, how could a coat hanger push it out, but not multiple half gallons of gas being thrown down it?
could the anti-siphon flap gotten stuck? i dont even know what it looks like or if thats possible.
suggestions?
Old 11-25-2006, 03:13 PM
_JB_'s Avatar
I've seen people pull rags out of their tanks. Pissed anyone off lately?
RPM WS6's Avatar
Honestly, this is one of the oddest problems I've ever seen anyone post about on here, ever.
The fact that the only difference between this successful fill-up and the last failed attempt was that you poked a coat hanger in the fill neck, leads me to beleive that something was stuck in there. But what?
Reminds me of cleaning out a clogged downspout on a gutter. You can put all the water in the world in that gutter but usually you need to poke something down to push out the blockage.
Bad part is, if you did have a blockage, now it's floating around in your gas tank.
Old 11-25-2006, 04:14 PM
yea i know i figured ill find out soon enough...if it gets sucked to the pump it should cut the gas and choke it dry. i have an SES light that may or may not be related. my freon is low and it pops it on sometimes.
i only drive the car a couple times a month. it sits in the underground garage at the condo and i dont think any of the old people would have done something. and if its not there its cause im driving it work where its in another parking garage thats pretty well monitored. who knows. it boggles my mind. hopefully if something was stuck in it, it will deteriorate from the gas, or not cause any harm floating around.
Old 11-25-2006, 05:05 PM
_JB_'s Avatar
I would pull the tank and check it out. It's pretty easy to get out.
Old 11-25-2006, 05:35 PM
i heard its the biggest pita to pull out. ill just drive it till something happens ...then worry about it
Old 11-25-2006, 05:42 PM
RPM WS6's Avatar
The '98 and older metal tanks are worse. But none of them are exactly fun.
Old 11-25-2006, 08:22 PM
_JB_'s Avatar
I had no problem getting mine out, probably 20 mins. Hell even with the catback pipe being welded to the I-pipe I was able to get it out with some manunvering (sp). I would much rather drop the tank than change the plugs.
Old 11-25-2006, 08:30 PM
RPM WS6's Avatar
Wow.
Tell ya what. If my tank ever needs to be dropped, you do it for me. And I'll change your plugs.
Old 11-25-2006, 08:52 PM
TORCHD 02 TA's Avatar
hehehe sorry Roy
but wow that is weird man no idea what to tell you. seems like the floater in the gas tank is what is fooling you and the pump????
Old 11-25-2006, 11:54 PM
_JB_'s Avatar
Wow.
lol, alright
Old 11-26-2006, 04:57 AM
YoMommasTA's Avatar
i've read threads about this problem before,do a search.From what i remember there is some type of roll over protection valve in the tank that can get stuck.
Old 11-26-2006, 09:52 AM
couldnt find anything about the rollover valve with the stock setup.
Old 11-26-2006, 09:54 AM
YoMommasTA's Avatar
i'll look and see if i can find it,i've read about this at two times in the past
Old 11-26-2006, 03:51 PM
WayneSS01's Avatar
I read about it also. But I think it was on ls2.com
Old 12-01-2006, 03:44 PM
MRZ28's Avatar
I am having this same exact problem right now. but my tank is dead on E and wont take any more gas... it happend to me about 3 weeks ago also, I let air out of some valve at the front of the engine, and then went back and filled up fine. now it is not working for me this time around so it leads me to believe that that may have not been my solution. so bumb for any help
Old 12-01-2006, 03:49 PM
The Professor's Avatar
maybe
rofl..
Quick Reply: ever fill up and have gas squirt out?
