high oil pressure!!!
Old 12-08-2006, 03:41 PM
Trashed's Avatar
Default high oil pressure!!!
at cold start it gets up to like 75 psi and when it warms up it goes down to like 65 when im driving normal. any help please?
Old 12-08-2006, 04:04 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,460 Likes on 1,053 Posts
Lots of threads about low oil pressure, not too many about high oil pressure...
Has it always done this, or is it recent?
Old 12-08-2006, 04:34 PM
warscout2's Avatar
my car runs at about the same but that becouse im using 6 quarts of 5w30 moble 1
Old 12-08-2006, 06:23 PM
Trashed's Avatar
no i did the pcv delete and put on a ls6 intake and i noticed the jump in the pressure.
Old 12-08-2006, 06:33 PM
BLKWS.6's Avatar
You may well have got some gasket material from the swap that got into the inner workings and is obstructing an oil passage.
Old 12-08-2006, 07:05 PM
RPM WS6's Avatar
....or you may have damaged the oil pressure sending unit when you swapped intakes.
Whe you say PCV delete, what exactly do you mean? Are you using a breather on the valvecover now?
Old 12-09-2006, 01:13 AM
Trashed's Avatar
i replaced the oil sending unit when i swapped intakes and yes im runnin a breather on the valve cover.
Old 12-09-2006, 10:25 AM
RPM WS6's Avatar
Maybe the new sending unit is not reading properly?
Old 12-09-2006, 10:46 AM
taintedmeat's Avatar
What was your pressure like before?
Old 12-09-2006, 11:04 AM
staringback05's Avatar
you could have several things.....added just a bit to much oil, filter might have some crap in it or be jammed, etc etc
Old 12-10-2006, 12:29 PM
Trashed's Avatar
the pressure before was at like 50 i wanna say, before the intake and pcv delete
Old 12-10-2006, 01:05 PM
the intake wont have anything to do with the oil pressure....however that pcv delete could
Old 12-11-2006, 03:20 PM
blkbird's Avatar
My buddy replaced his with a borg/warner sending unit and his pressure is exactly like yours. The car still runs the same. I think its the sending unit. Im about to change mine out because its jumping around all over the place.
Old 12-11-2006, 08:50 PM
BigDaddyBry's Avatar
Many people on this forum would love to have your problem.
What does your pressure read with just the ignition on? That should rule out the sending unit as the source of the problem.
Old 12-12-2006, 05:51 AM
lovin myls1's Avatar
Probably just the difference in accuracy of the sending units.One being more or less accurate than the other.
Old 12-12-2006, 08:33 PM
Trashed's Avatar
so it shouldn't be anything to worry about?
Old 12-12-2006, 08:40 PM
borg warner=
when it comes to those parts just get the ac delcos
Old 12-13-2006, 11:14 PM
Reidonly's Avatar
A friend of mine just picked up a '98 Vette and one night we met up so I could check it out, and the very first thing I notice is his oil pressure was pegged at 80 at idle. He checked the digital computer readout and it said something like 119! Mine is like 50 at idle I think. Still not sure why his is doing that.
Old 12-14-2006, 08:33 AM
I'd seriously have that looked at due to the fact he just purchased the vehicle and it may be a dealer or previous owner's attempt to mask something wrong with the car.
Old 12-14-2006, 10:47 AM
On the tree
Sneakyws6's Avatar
If in doubt get a manual oil pressure unit and install it.
Turning the key to "On" will not tell you if it is a bad sending unit since there is no pressure unless the car is running.
Either swap the sending unit out with w known working unit or replace it again. I have seen them be bad right out of the box new.
