BUNCH of codes and descriptions... WHAT DO THEY MEAN? HELP!
[Brake] C0266 - Unknown (History)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[HUD] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[HUD] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Restraints] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
[Restraints] U1096 - Loss of Communications with IPC (History) (Immature)
My Service vehicle light was on (NOT SES).... I didn't even know I had one
The ABS inop light is coming on and going off.
Also, traction control is horror-movie flashing (the light). If you turn it off, it turns right back on.
All of this after just pulling valve covers and rockers! I can't find anything that is loose. Maybe my turbo setup burned something, though nothing I can see...
Also, was thinking the car was stinking and my evap maybe acting up... then I got this code as well:
[PCM] P0442 - Evaporative Emission (EVAP) System Small Leak Detected (SES) (Old) (History) (Current)
These were already present and seemed to affect nothing:
These are really the new ones that I'm more bothered by:
This maybe traction control related?
Originally Posted by joshp14
Did you have the ground off the back of the head? Check all your ignition fuses in the fuse box as well.
