Pulling Fuel Rails - How Do I?
Here is directions on how to disconnect the fuel lines and the injector connectors. The 2nd and 4th photos and their respective directions pertain to you.
http://www.ls1howto.com/index.php?article=18
From there, I suggest removing the fasteners that hold the rail to the intake, then remove the black clips that hold the top of the injectors to the rail. Carefully pull the rail off each injector, leaving the injectors in the intake. With the injectors in place you will minimize debris getting into your injector bungholes .
