signs of bad window motor. - LS1TECH
Thread Tools Search this Thread
Old 12-19-2006, 07:09 PM   #1
silverbandit0996's Avatar
Default signs of bad window motor.
ive never had power windows so i don't know how to tell if the window motor is going out. here's whats happening, my window will go about halfway down then stop. then about 3 minutes later i can roll down it down some more, and so on. it's the same way going up. is this the window motor or something else.
silverbandit0996 is offline   Reply With Quote
Old 12-19-2006, 07:22 PM   #2
It depends. Which window is it?
The reason it works then stops and works again later is the internal breaker.
If it the passenger window our kit may help you out. Click the link in my sig and look at our videos.
If it is the driver side window it is probably going out. You may take the door panel off and grease the tracks with lithium grease no matter what window it is and get it to work a little better.
gnomee is offline   Reply With Quote
Old 12-19-2006, 07:47 PM   #3
Splitz's Avatar
Your window motor is toast, I had the same issue a few months ago, two hours later, VOILA!
Window Motor Re pair Link
Now, I got the Siemens window motor from Autozone for $55 plus shipping and it has a lifetime warranty. You can do it yourself, click link above for EXCELLENT walk through! Took me two hours first time, next time it won't take as long. Would not suggest taking it to a shop/dealer, your gonna get nailed with an hourly rate. I was quoted 3 hours @ $75/hour. plus the part.
Good luck! Report back when fixed!
Splitz is offline   Reply With Quote
Old 12-19-2006, 07:52 PM   #4
its the motor, has happen twice in my 3rd gen. the window gets slower and slower than starts stopping. the brushes wear out and it takes more current to make them move and causes more heat, etcc..
you might get away with making them last alittle longer buy doing what gnomee said, but after awhile your going to have to change out the motor or at least the brushes.
MdFormula350 is offline   Reply With Quote
Old 12-20-2006, 10:59 AM   #5
+1 for splitz...anything else is just a bandaid
98ws61le is offline   Reply With Quote
Old 12-20-2006, 11:32 AM   #6
Actually our kit is not a bandaid. Thats why you end up replacing the motor over and over. None of our cars that are DD with the kit installed have EVER had a motor replaced. Here is a link to a much bigger discussion on how and why it works.
http://www.ls1tech.com/forums/showthread.php?t=609435
Old 12-20-2006, 11:52 AM   #7
i read that link but honestly didn't pull any info about your kit...i understand that your apprehensive about give the instructions out but can you please explain in detail what your kit does..
I'm assuming from your parts list that your taking direct battery current and using the relays wired up in a reverse polarity fashion (a la 5 wire door lock systems) the drive the motors.....is this a fair assumption....again with out looking at the GM schem your doing this to bypass the resistance of any small awg factory wiring and also, if any, components in the circuit...possiable BCM...did i nail it?
Old 12-20-2006, 12:04 PM   #8
Yes the kit is giving the motor proper voltage directly from the battery instead of the reverse polarity method that they currently use which pulls current thru 20ft of small gauge wire before it gets to the motor.
This is explained in the 4th post of that thread. Guess not detailed enough though.
Old 12-23-2006, 06:15 PM   #9
well it is the drivers side so i guess the little kit thingy you sell wouldn't work anyways.
Related Topics
Thread Thread Starter Forum Replies Last Post
power window issue blue09rocket Stereo & Electronics 1 07-31-2014 09:55 PM
When Down, Window "clunks" When Door is closed Rayzor442 General Maintenance & Repairs 7 05-13-2013 11:30 AM
Second power window motor going out. Cerwin Vega Fan Racer's Lounge 3 06-07-2005 10:42 PM
Window Motor TCrow2002WS6 Racer's Lounge 5 01-26-2005 08:31 PM
Window Won't Roll Down SICKBIRD General Maintenance & Repairs 9 10-08-2004 09:06 PM
Tags
02, 2002, bad, car, check, motor, motors, sign, signs, slow, symptoms, trans, window, windows, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
