2000 ta turn signals
Old 12-28-2006, 07:04 PM
FDXHAWK's Avatar
Default 2000 ta turn signals
High, my turn signals blink very very slowly is this a common problem and if so what is the proper way to fix it
Old 12-28-2006, 08:05 PM
Da Swami's Avatar
Could be your flasher going out.....?
Although from what I've seen that usually makes it blink faster.....
Old 12-29-2006, 03:35 PM
FLA02TA's Avatar
Flasher unit going. You probably hear a slight grind/click sound if you have the radio off if you listen near the dash.
Mine just went and the flasher unit fixed it up.
Refer to this thread w/photo to find it. It's kinda hidden and hard to find if you don't know where to look.
https://ls1tech.com/forums/showpost....81&postcount=2
