where is the PCV valve located on a 98?
LS1Tech Administrator
Received 1,489 Likes
It's a little buldge in the PCV line running off the passenger side of the intake. It rests right on the upper most part of the valve cover (near where it meets the intake) about halfway back on the cylinder head. If it's the stock valve, you'll find it wrapped in foam. Inside the foam is a rubber boot. Inside the boot is the PCV valve.
Originally Posted by Da Swami
Are you supposed to re-wrap it in foam?
Or can you just get rid of that part altogether?
Originally Posted by fatboyq
I plan on doing a minor tune up this weekend and want to know where it is instead of looking for it.
