Pennies in my Engine! VIDEO...
I recently noticed a noise coming from my valvetrain that sounds like a penny being shaken in a glass bottle. The car doesnt have any problems running besides somtimes it takes two tries to startup or i gotta prime the fuel pump twice, which i believe is probably something in the fuel lines. This is the second motor in the car (or so i was told by the previous owner) so I have no idea how many miles are on it. It has 918 blue striped springs.
Click here to see Video
Hopefully someone knows what this is...
EDIT: The noise only comes from the passenger side of the engine
What should i be looking for when i pull the valve cover? The other side doesnt make that noise so should i pull that cover off too and then compare the two?
Im going outside now to pull the cover, ill be back tonight with some pictures
I remember someone posting this pic a few weeks ago. Anyways here's an example of a broken spring. (2nd spring from the left)
Also try looking for a broken rocker arm, or excessive valve lash (rocker arm slop between the valve stem and the rocker arm) which would indicate a bent push rod. Or even better if you still cannot find anything pull the rocker arms off, take out all of the push rods and roll them on a flat surface to see if any are bent. Hope it helps
Originally Posted by 1sick'98WS6
Similar problem here... my pushrod was bent in three places and broken in half
I havnt had time to take the valve covers off so no results yet...
Sounds like the a/c compressor clutch dragging. Does it do it with the a/c running? It should go away ith the a/c running. Or it sounds like a loose bearing in a tensioner pulley.
I would suspect a valvetrain problem to have more of a tapping especially a broken spring.
