need help figuring this out
Old 01-08-2007, 05:00 PM
krink85's Avatar
Default need help figuring this out
ever since i have had my car i have had a slight problem with the car starting. the problem usually happens after i have driven my car and shut it off and going back to start it again. to get ti to start i have to hold the igniting on and run through the gears and it kicks right up but there has been a couple of times where it didnt start and i would have to wait for it to cool off. i am not sure if the temp of the car has anythign to do it but it seems ike it starts right up when cold.
Old 01-09-2007, 01:26 PM
rocketrider93's Avatar
could be that the starter solenoid is getting too hot. how old is it. may be time to change it out. does it crank over but won't start or is it just plain dead till it cools down again?
Old 01-09-2007, 03:43 PM
EchoMirage's Avatar
check the ground cable. corrosion on the main ground, to the engine block, could make a hard start issue after running a while.
Old 01-09-2007, 05:23 PM
krink85's Avatar
there is no turning over, nothign to make me think it was from securtiy problems. the former owners siad they took it to a dealership and they couldnt figure it out. where is the ground cable on the engine, is it easily accessible?
Old 01-09-2007, 07:55 PM
EchoMirage's Avatar
i dont know where on LS1s, but easiest way to find it is follow the negative cable from the batter, and see where it goes. there might be one or two other wires, but you should follow the thickest, heaviest cable. it should go to the block, attached to a bolt and nut.
Old 01-10-2007, 06:34 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Moving to General Maintenance & Repairs Forum (from Pontiac Firebird Forum)...
