LT1 With 160degree stat, should I have heat?
Old 01-15-2007, 09:34 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default LT1 With 160degree stat, should I have heat?
Seems I never get any heat before I get where I'm going, normal for a 160 degree stat, driving in sub freezing temps?
Old 01-15-2007, 09:38 PM
Tainted's Avatar
lol no not really might wanan flush out your heater core
Old 01-15-2007, 09:44 PM
Sgt. Spuds's Avatar
If its just sitting there ( long drive through lines ) the temp will start to go up, but as soon as Im back on the road it cools back off again... always ~ 180degrees
Old 01-15-2007, 09:45 PM
Tainted's Avatar
id really flush out the heater core and see if that helps. but if youre not getting heat till yur there (unless its a short trip) then that doesnt sound right
Old 01-16-2007, 05:18 AM
Dex
Dex's Avatar
Are we talking no heat or little heat? Put the factory one in and I bet you get heat agian.
Old 01-16-2007, 05:37 AM
NOTAV6's Avatar
i dont think its uncommon for that to happen with LT1's with the 160
I have the 160 and a EWP and mine takes a little while to heat up but i will get heat eventually and blows pretty hot when i warms up but it does take a while
Old 01-16-2007, 05:54 AM
Ironxcross's Avatar
I dont have the EWP, but it takes maybe 3-5 minutes for heat to come out, but when it does, its hot. It just takes longer.
