Speedo Keeps jumpin Around
Old 01-20-2007, 01:16 PM
DrivenWS6's Avatar
Default Speedo Keeps jumpin Around
Alright well my speedometer has been like cutting out for a while. Whenever I want to get on it or get into it on the highway it will like dip down to like 50 or 40 or whatever and then when I let off or get out of the gas it comes right back up to the speed im going. Well I pulled the VSS out a while back and cleaned it off and it got better for a while but now its getting worse. Well I went to get a new VSS and I was talkin to a guy in a GM dealership that I know and he said to make sure its not my cluster...that GM has had a lot of problems with their clusters but I havent heard of that too much on Fbody's. And he also said that it could be I have too much play in the output shaft of the tranny and whenever i get into the gas it wants to pull away from the sensor therefore not getting a signal. But I have also never really heard of that before with the T56's so I thought Id run it past you guys to see what you thought. Any help would be great. Thanx
Old 01-20-2007, 08:14 PM
DrivenWS6's Avatar
anyone got any ideas?
Old 01-20-2007, 08:20 PM
taintedmeat's Avatar
Sounds like it could be vss, but if you wanted to check the output shaft couldn't you just go try to wiggle it on the end of the trans?
