how to change the TA fog lights?
Old 01-25-2007, 10:17 AM
TX_SS's Avatar
Default how to change the TA fog lights?
how do i chang those? any easy way?
Old 01-26-2007, 06:50 PM
N3V3RL8T's Avatar
If you have a small enough arm you can simple open the head light doors(turn on light) and reach down and turn them about a quarter turn and they should pop out. of you replaceing the housing, you need to get under the car and pop out the 3 plastic rivits on the black slopeing trim peice, pull it back and you should be able to reach them . just take a screw driver and pop out the center portion of the rivits out so you can re-use them. hope this helps.
Old 01-26-2007, 09:59 PM
toofless916's Avatar
i think its a pain in the anus myself
Old 01-26-2007, 10:34 PM
lomaximumta's Avatar
loosen the plastic cover right near the front air dam under the car and it opens a little slot that you can reach you're hand up in and pull the light out.
