Coolant Leak!!!!
Old 01-27-2007, 07:47 PM
Joker98's Avatar
Default Coolant Leak!!!!
Well the 100k mile curse has arrived! My 98Z just hit the century mark last week and now I've noticed a coolant leak. Im pretty sure its the water pump leakin. I checked the search and noticed one post stating that there is no weep hole on our pumps?? Can I get away with doin just the gaskets or should I just eat it and get a pump? Any perticular brand better than another?
Old 01-27-2007, 08:48 PM
03 BUSA's Avatar
Since the pump is pretty easy to install I would say if you have no visible signs of the wp shaft falling apart or any signs the cooloant has eaten any of the material away I would just repalce the gaskets. If you choose to replace the pump, which is not a bad idea by any means I would get the GM one. Your first one lasted 100K.
Old 01-27-2007, 10:48 PM
02Z06MATT's Avatar
if the surface area of the pump is chewed up, then u should get a new pump, I recommend a meziere pump, not too expensive and picks up some hp and keeps ur car cool
Old 01-28-2007, 06:00 PM
Joker98's Avatar
Thanks guys, I appreciate the help!
Old 01-30-2007, 05:42 PM
Black_98Z's Avatar
yea, seems like you need a new water pump
Old 02-14-2007, 01:39 AM
JasonWW's Avatar
Looks like I have a leak behind the water pump pully. Is there a weep hole under there or not? Seems like there might be.
Old 02-14-2007, 01:52 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
There is a weep hole.
Old 02-14-2007, 08:53 AM
taintedmeat's Avatar
You don't want that for a dd.
