Car runs like poop
Car runs like poop
It is a 98 formula. Problem is no codes. It idles like it has a mis and smells like gas. It is like it is flooded. When it dies it takes a couple times to get it started. I have done plugs, wires, injectors, coils, check fuel pressure, compression is good. What is the problem???
If you have a techII check the air temp sensor and the coolant temp sensor, if one of those is way off it could be dumping fuel to compensate, just a thought. Good luck -Dave
