Replacement Bulbs Anyone???
I need new head and fog lamb bulbs. Do you guys have any recs for a brighter bulb that won't require me to change any wiring? Can the fog lamp bulbs be replaced and not the enitire assembly? Let me know asap, i have a vehicle inspection in about 2 weeks!
Go here and find out the bulb numbers for all of your cars bulbs, including the fog light bulbs.
http://www.sylvania.com/ConsumerProd...de/default.htm
I just had to replace a fog light the other day on my 99 ta. It ranks right up there with changing the number 8 spark plug. it's a huge PITA the best way I found to get to it was from the bottom. Remove 3 plastic push pins from a plastic flap in front of the fog lights and you can pull it back far enough to slip your hand in. The bulb twists lose and pulls out of the housing just like all the other lights on the car. If you have small enough hands you might be able to get to it from the top behind the window washer fluid reservoir. Good luck, it sucked!
