ASR button light out!!!!
Old 02-05-2007, 10:02 AM
Candyredz28's Avatar
Default ASR button light out!!!!
The asr button light went out recently anybody know how to fix it???
Old 02-09-2007, 04:07 PM
anybody knows, it gets pretty annoying when little **** like this keep adding to my car
Old 02-09-2007, 04:42 PM
2001NBMZ28's Avatar
Just the light in the switch? Is the ASR OFF working, no service vehicle light in the cluster on? If the system is working fine otherwise the switch just plugs in behind the bezel and easy to replace.
Old 02-09-2007, 04:52 PM
the asr is working, its just the light on the switch went out.
Old 02-09-2007, 05:44 PM
2001NBMZ28's Avatar
I'm not one for just replacing parts, but it's about $25 list at the dealership (PN 10273877 but doublecheck), still might be something else. Do you know someone with ASR on their car and can swap switches for a few seconds to make sure that's it? Don't want to recommend replacing the switch and you still having the same issue.
Old 02-09-2007, 07:18 PM
RUDE SS's Avatar
Yeah you cant replace the bulb. Get the new switch and plug and play.
Old 02-09-2007, 09:06 PM
Are u sure it doesnt have to do with something else like turn signals because when my turn signals went out the asr went out also.
Old 04-21-2008, 10:46 PM
Vega's Avatar
Mine went out couple of days ago. Are you fellas sure I can't just replace the bulb?
Old 04-22-2008, 03:49 AM
bradl1982's Avatar
Mine went out about a year ago. I just went and bought a new switch for $25 and it fixed the problem. You might be able to just solder a new bulb in there but I broke the switch while trying to take it apart. Plus finding the bulb would be a pain in the ***. Your best bet is to just buy a new switch.
Old 04-22-2008, 09:00 AM
tylerdj's Avatar
Why do you need the light in the switch?
Old 04-22-2008, 06:27 PM
tording99Z28's Avatar
You don't. LOL Mine has been out for months now and it doesn't affect one single thing. You already have the "ASR off" indication in the cluster to let you know what mode your ASR is in so why do you need the light? Save the $25 and don't worry about it.
