failed inspection, steering column is loose
Old 02-09-2007, 02:11 PM
HawaiianZ28Rider's Avatar
Default failed inspection, steering column is loose
anybody know how i can fix this?
Old 02-09-2007, 02:59 PM
Restricted User
MikeFbody's Avatar
column is held in by 2 large nuts under the dash and 3 bolts at the inside of the firewall. You need to drop the underdash panel and knee bolster to see them.
Old 02-09-2007, 06:43 PM
pkincy's Avatar
What car do you have?
Do you mean the whole column is loose?? Very unusual but can be the major mounting points of the column itself in that case.
I find it much more normal for the steering wheel itself to become loose with wiggled side to side. That is a broken stud inside the column itself.
Perry
Old 02-09-2007, 06:52 PM
blizzard's Avatar
Perry
mine is loose at the wheel also can it be fixed? thnxs in advance
Old 02-09-2007, 06:58 PM
LSXNV's Avatar
+1 for loose column
Old 02-09-2007, 07:05 PM
ksuburban's Avatar
the bushings in the column might be worn out.
Old 02-16-2007, 12:49 PM
yea if you push up or down on the wheel, it budges....not to bad though because it take alot for it to move
can i repair this myself or do i need special tools for the repair, i dont know exactly what needs to be replaced or tightened
Old 02-19-2007, 04:27 PM
pkincy's Avatar
A helms manual is your friend. Particularly if the wheel moves and the column doesn't. Than you will need a special tool to get in the column and you will also need to pull the airbag which I would never try without a Helms.
If the column is moving and the steering wheel is only moving with it than it is likely an exterior fix and that is much much easier.
Perry
Old 02-19-2007, 05:30 PM
Closed ex-Sponsor Account
autotrix's Avatar
The tilt bowl bolts could also be the culprit, causing the steering wheel itself to pivot as a whole.
It is not so hard of a job with the right steering wheel puller set!
