drivers window internal parts going bad ???
Old 02-11-2007, 10:17 PM
CULATR's Avatar
Default drivers window internal parts going bad ???
today when i got outta my camaro noticed the drivers window was kinda of tilted away towards the car and not up against the outer door weather stripping piece mounted on the door ( when the doors opened) i looked at my pass side and its up against the outter weatherstripping when the doors opened? anybody know if this is normal i dont think it is so how do you fix it and what is it caused by??? Someone chime in and help me out on this please.........
Old 02-20-2007, 10:38 PM
Black-LS1's Avatar
hmm i have the same problem...driver side...anyone?
Old 02-20-2007, 11:58 PM
dpren's Avatar
There are two guides in each door that support the windows. Both of mine were broken and my window was doing the same thing as yours. Pop off the door panel and check them out and see if they are broken. They are located on the top of the door just under the inside weather striping. They are extremely easy to change out, just one bolt each.
Hope this helps,
Doug
Old 02-21-2007, 11:23 AM
2001NBMZ28's Avatar
http://shbox.com/1/stabilizers.jpg
