Car overheating big time, need help!
Old 02-18-2007, 07:39 PM
916LS1's Avatar
Default Car overheating big time, need help!
I had a very slight coolant leak, so I replaced the gaskets and got the car all back together. It didn't overheat before, it just had a slight leak. I put one jug of dex in, then started the car, then proceeded to put more water in. It only took another half jug of water. The coolant dipstick says its full, but the temp gauge goes into the red and keeps going
I've had the water pump off a few months ago during my cam swap, and no problems overheating since. Whats funny now, is that the heater and defroster don't blow hot air... WTF is going on here? Gotta be something simple. Could I have broken the pump putting it back on? It doesn't seem like there is any coolant flow into the engine, the radiator lines don't get hot.
Please help!
Old 02-18-2007, 09:20 PM
keliente's Avatar
Did you bleed it?
Old 02-18-2007, 09:29 PM
916LS1's Avatar
How do you do that???
Old 02-18-2007, 10:33 PM
Closed ex-Sponsor Account
autotrix's Avatar
Do a search on overheating, you will find a good write-up!
Old 02-18-2007, 11:11 PM
keliente's Avatar
...there is a small hose that goes from the throttle body to a small metal pipe on the right side under the intake. Remove that hose and put a paper towel under the pipe. Fill the system through the radiator until fluid comes out of that hose and then put the hose back on.
Old 02-19-2007, 10:35 AM
916LS1's Avatar
Awesome! Thanks, I'll give that a try!
Old 02-19-2007, 05:31 PM
Moderator
thechef's Avatar
yup you have air in the system bleed it like posted above and you will be all set
Old 02-19-2007, 07:53 PM
916LS1's Avatar
That did the trick, thanks guys! I can't believe it was that simple. Just a little air caused the entire cooling system to fail...
Old 02-20-2007, 12:19 PM
CAMAROZ28SS's Avatar
you gotta bleed the coolant lines. i had the same exact problem with my old 95 z28
