Cam is missing a chunk - Do I need to replace it
Old 02-22-2007, 11:05 PM
SOM_of_a_Beach's Avatar
Default Cam is missing a chunk - Do I need to replace it
Okay, in an effort to change my oil pump. I have removed my s/c, radiator, water pump, pulleys and front timing cover. I did the pulley and timing cover removal from under the car. My husband walks out and says "did ya notice your missing a chunk from your cam?" I get out of under the car and this is what i see.
How bad is it and how badly if any will this affect my car?
Attached Thumbnails Cam is missing a chunk - Do I need to replace it-car1.jpg   Cam is missing a chunk - Do I need to replace it-car3.jpg   Cam is missing a chunk - Do I need to replace it-car4.jpg   Cam is missing a chunk - Do I need to replace it-car5.jpg   Cam is missing a chunk - Do I need to replace it-car2.jpg
Old 02-22-2007, 11:19 PM
98turbls1's Avatar
Is that a stock cam??? If so then I would just go get a 02 Z06 Cam or something similar... I'm not so sure that I would run it that way... God I wish that I had a gf like you... I can't even hardly get mine to ride in the car after I put my own blower on.. =) Goodluck to you and let us know how it turned out...
Old 02-22-2007, 11:36 PM
Tomorrow I will call the shop up that built it (i bought it this way - long story) and see what cam its running. If it is stock I have one or two stockers lating around the house. Lord, I am affraid to keep taking shiat apart. I dont wanna find any more broken parts. The whole point of me doing this project was to save money LOL
Heck if its gotta get fixed might as well do it as my car is dismantled. I have 3 boxes of parts i ripped out and like 10 baggies full of nut bolts washers and screws. (But i named everything with stickies so I wouldnt forget)
Old 02-22-2007, 11:53 PM
Kleeborp the Moderator™
MeentSS02's Avatar
If it were me, I'd replace it, no questions asked.
Old 02-23-2007, 12:19 AM
sp00rkz's Avatar
any damage, abnormal wear or more than .002 of normal wear = new cam.
Old 02-23-2007, 06:03 AM
staringback05's Avatar
when exactly did this happen, i mean i dont see how you could have done that....see that chunk lieing around anywhere?.....a new cam wouldnt hurt you...
Old 02-23-2007, 06:21 AM
LS69TA's Avatar
I wonder where that chunk ended up? Looks like somebody dropped it or something before they put it in...depending on the shop that did the work, it's possible.
Old 02-23-2007, 06:31 AM
she did her own work......motivated lady, didnt think youd take it on this soon....
Old 02-23-2007, 07:04 AM
blkbird's Avatar
Isnt that the crank snout??? Never heard it called a "cam".
Old 02-23-2007, 07:11 AM
brad8266's Avatar
that looks like the crank to me.
Old 02-23-2007, 09:47 AM
mcamarols1's Avatar
^^ thats what i was thinkin, ull b alright
Old 02-23-2007, 09:55 AM
keliente's Avatar
That is the crank snout. If your cam was sticking that far out of your engine you'd be in big trouble
You said you have a s/c. Is it possible that someone maybe started to key the crank for it, and gave up?
Old 02-23-2007, 09:58 AM
brad8266's Avatar
keliente, why isnt the vette in the sig? I thought you just bought one.
Old 02-23-2007, 10:36 AM
I think you maybe right. There was no pin for indexing it. I was under the car and no pin came/fell out. And I use a piece of card board under my car to slide in and out and i bag and tag everything that comes out of the engine so, i dont forget what it was. I am pretty organized when it comes to working on her.
I can only imagine someone tried indexing it and stopped. I called up the shop that built the car and the reffered me to the shop that built the engine. He says he is gonna try to go thru his files and see what he remembers from this engine as it was built like amost 2 years ago.
The shop that built the engone is like 400 miles north of me. Maybe I will take more pics while the sun is up. I guess I will have to put my project on hold till I figuire this thing out. Sucks.
Thanks for the help folks.
Old 02-23-2007, 12:24 PM
brad8266's Avatar
I wouldnt worry about that nick unless it causes issues with the crank pulley seating.
Old 02-23-2007, 04:13 PM
UPDATE:
Okay, its the snout and its got a crack. I can live with that. But, I did notice that the pin used to keep the dampner moving with the crank actually broke and is stuck in the crank flush against the crank. So i have no way of grasping it to pull it out. I ran my finger thru the square whole in the ati super dampner and there were shards of metal. Probably from the pin the broke off.
Any thoughts on how to get it out since there is no way of grabbing it?
Thanks,
Crystal
Old 02-23-2007, 05:20 PM
hey crystal where you get the motor built, i see you said it was like 400 miles north of you....wanna see if i know the company
Quick Reply: Cam is missing a chunk - Do I need to replace it
