GC in Winter
Should be NO problem, even with the unusually colder winter you've just had. Now if you were in northern New England, or the upper midwest, then you might have to look for a slightly thinner oil. Even though it is called a 0W-30, GC is an extremely thick 30 weight oil in the upper range of the 30 weight specs, closer to a thinner 40 weight.
Originally Posted by dailydriver
... Even though it is called a 0W-30, GC is an extremely thick 30 weight oil in the upper range of the 30 weight specs, closer to a thinner 40 weight.
