What do you use for ramps/jacks?
Kinda a newb question, as I am, but I haven't run across this as a discussion issue. Probably cause most people on here are such pros!
As a fairly new F-body owner, I was wondering if any of you guys had any innovative ways of ramping or lifting your car with the low clearance.
I'm not talking if you have a hook up and a lift at a local shop, but I'm looking for the best/safest/cheapest way to do maintanance and on the underbody. Rhino ramps from Walmart with 2 x 12 boards is what I've been told? Not only to learn, but I'd bet some of you guys have some really crazy ideas too (post some pics if so!).
Lots of guys use the Rhino ramps. I just use some foot long 2x4s and 4x4s. I line them up and drive up on the 2x4s first, then the 4x4s. That way I had plenty of room to get my jack under the car. I'm cheap and these were leftover from some projects around the house.
LS1Tech Administrator
Received 1,491 Likes
+1 for the Rhino Ramps. They work great.
I use rhino ramps...but I need to get new ones since I was pulling the fiancee's car onto them( with a very very touchy gas pedal and a front wheel drive). Well you probably guess what happened....gave it alittle too much gas and spun the ramps back under the car. Since no damaged happened to the car it was pretty funny to see the look on her face when she saw what i have done The ramps ended up getting about a 3 deep cut in them when the came down on them. So anyway be careful with a front wheel drive.
FWIW, I use the Rhino ramps all the time for my FWD Bonneville and Monte, and never had a problem.
I use a 2.5Ton Floor Jack and jack stands if I'm working on my ride at home. If I need to do some extensive work underneath the car then I goto a DIY shop (a few minutes away from where I live) that is equipped with a car hoist.
I actually feel safer with the ramps over jack stands.
yeah, don't trust much on the camaro. I just got the ramps for myself. Maybe I will make my own one day.
I know theres still some crazy ramp setups out there, any pics?
Do it yourself shop? now thats nice! Anybody else have that in their area?
Since my car is still as stock height, I have no issue using a 2-ton floor jack to lift the car. If I'm leaving the tires on, I jack the car up and slide the ramps underneath. I had an incident with driving my Z34 up on the ramps once and I refuse to do it anymore. If the tires are coming off, I just put it on jack stands. I only have 2 stands so it can't go up on all 4s if the tires are coming off.
I use a floor jack under the K member and then lower it onto Rhino ramps. The ramps moved once on me and that was enough. I trust the ramps more than jack stands, but I have a pair just in case. If its on the ramps block BOTH back wheels for your own saftey. I just roll off the ramps when done.
