Weird squeaking sound
Old 03-16-2007, 10:16 AM
GMRL's Avatar
Default Weird squeaking sound
So Ive had this annoying squeaking sound on my 02 TA for the past couple weeks. At first I thought it was a pulley, so I removed the belts and spun each pulley by hand. The tensioner was noisy and had some play in it so I replaced it. But that didnt fix it. Next I removed the AC belt to eliminate those pulleys, but still squeaky.
It doesnt squeak all the time, usualy only after driving for a few minutes, and even then it goes away when I give it some gas. So yesterday I pulled over when it started making the noise again and started poking around trying to find the source, I was thinking it was the belt, so I took some tension off and no change. For some reason I pulled dipstick out and it stops I put it back in and starts again. Now I figure its gotta be some sort of vacuum leak thats making that noise. Does anybody know where I can get a vacuum diagram?
Old 03-16-2007, 05:04 PM
GMRL's Avatar
I think this is whats happening.
https://ls1tech.com/forums/automatic-transmission/621638-trans-guys-please-help-wierd-noise.html
