Need everybodies help on this one
550-600 on the tach sounds like the in gear idle with foot on the brake - mine read 525-585 on a scanner. In gear idle/Park-Neutral idle are different. Don't know if there's a difference between years though?
im not resettin it the right way. which would be with a laptop and special program. i know the needle in the tach is wrong, so im gonna let the car run at normal temp at idle and then take out the needle and put it back where i believe it should be in the general area.
